DHCP: The name in network control block in use
BobGreer65666
Hi there, thanks for reading.
I have an intermittent DHCP issue.  Random clients won't DHCP (first through SG220 switch; now have swapped in place C9200s).  They 'fix themselves' after a few hours.  The client-side error reads:
An error occurred while renewing interface Ethernet : The name specified in the network control block (NCB) is in use on a remote adapter.
The NCB is the data.
Have you seen this before?
Mark Elsen
 - If you are in   a transitional phase with different dhcp servers I would recommend to use short lease-times to start with.
 M,
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
