Difference between Upgradable IP Base Layer 3 and IP Services Adv. L3
reycapoy
    I would like to ask if what is the difference between Upgradable IP Base Layer 3 and IP Services Adv. L3? Focusing specifically to 3750 Catalyst switches.
    My understanding is that Upgradable IP Base Layer 3 can be upgraded to IP Services.  Is it possible to upgrade IP Services Adv. L3 to IP services?
Reza Sharifi
There are basically 3 types of licensees for the 3750 series. 1-Lan Base 2-IP Base 3-IP Servised.
Lan Base is very limited to just layer-3
IP Base is layer-2 and some layer-3 including static route, EIGRP Stub, etc...
IP services gives you all of the above and in addition full dynamic routing capacities including OSPF, EIGRP, BGP, VRF Lite, PBR, etc...
Reza Sharifi
Hello Reza,
      Thanks for your quick response.
Glad to help and thanks for the rating
Reza
Sure anytime.
