Difference of IOS Types
alexanderbauer
Hello togther
I'm searching for a overview about the difference IOS Description for Catalyst Switches:
Ipbase Wo/crypto
Ipbase Wo/crypto with Web based Dev Mgr
IP Base
Ipbase Wo/crypto with Express Setup
Our Platform is Cat 3560 G PS-S, 2960
9 Replies 9
Ganesh Hariharan
Hello togther
Ipbase Wo/crypto
IP Base
LAN base is subset of IP Base, and IP Base is subset of Enterprise. LAN base is L2 only; IP Base supports basic L3 function; enterprise supports all L3 functions and the  IP Base feature set includes advanced quality of service (QoS), rate limiting, access control lists (ACLs), and basic static and Routing Information Protocol (RIP) functions. Dynamic IP routing protocols (Open Shortest Path First (OSPF), BGPv4, Enhanced Interior Gateway Routing Protocol (EIGRP)) are available only on the IP services image.
W/O stands for without,  another way to make sure is that the file's name will have "k9" in it (mostlikely ipbasek9). That k9 will tell you for sure that it is crypto.
Hope to help !!
Ganesh.H
Remember to rate the helpful post
alexanderbauer
Hello
About this Feature it was clear for me but let me show you the follwing Part we implement on one Switch (all are Cat3560 with Layer2 Funktion)
the following flash:/c3560-ipbase-mz.122-53.SE2/c3560-ipbase-mz.122-53.SE2.bin"  this is the IP Base W/O Crypto with Web Based Dev MGR.
After a Reboot we can not integrat them anymore in the CisCo Network Assistant Uplinks are avaible.
Spantree is Ok everthing is working fine, later one we make the Update with IP Base c3560-ipbase9.mz122-53Se2.bin not works fine.
netlynkerx
I am very new to this community. I want to ask a question about different license type of IOS.
Now my boss buy a 3750X switch that is running ipbase IOS. A need come up to configure PBR on it. Some says that I can't use PBR on IPbase license. Now I have two questions as follow
  1. Does the switch need to run ipservice IOS to use PBR?
  2. If I need to use Ipservices for PBR, how to make my switch run ipservice?
  3. Do i need to buy seperate upgrade license?
  4. If yes, how much will it cost approx?
You can add anything that you think I need to know.
ankugarg
Level 3
Level 3
Lanbase can run limited routing..It has support for 16 static routes.
To run PBR we need to use ipservices license..Please work with your account manager to know the cost..Once they give you license file,oyu just need to run license install command.
So I don't need to change or buy new hardware. Am I correct?
Pardon me for being naive.
Absolutely...No need to change or buy hardware..If you are using universal image,then it is not even required to change the image....If you are running ipbase IOS,then you need to change the image to "ipservices" or alternatively change the image to universal,and install the ipservice license.
Mine is as follow
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Universal?
Yes,Universal...You need to get the ipservice license,and use the license install command after putting the license file in tftp or flash or any other below option.
3-mem-stack#license install ?
  flash1:  Install from flash1: file system
  flash2:  Install from flash2: file system
  flash3:  Install from flash3: file system
  flash:   Install from flash: file system
  ftp:     Install from ftp: file system
  http:    Install from http: file system
  https:   Install from https: file system
  null:    Install from null: file system
  nvram:   Install from nvram: file system
  rcp:     Install from rcp: file system
  scp:     Install from scp: file system
  syslog:  Install from syslog: file system
  system:  Install from system: file system
  tftp:    Install from tftp: file system
  tmpsys:  Install from tmpsys: file system
Thank you so much for your patient replies.
