Directing Traffic from WAN Interface to VLAN
chris_stewart
I have a router with two T1 connections going to different customers.  I need to direct all the traffic from one T1 to VALN 100 and from other to VLAN 200.  How would I accomplish that?
Jon Marshall
chris_stewart@nc.rr.com
Chris
You could either use vrfs where you have the first T1 and vlan 100 in one vrf and the second T1 and vlan 200 in the other vrf although not sure of vrf support on your router.
Or you could use PBR which will be supported ie.
vlan 100 = 192.168.5.0/24
vlan 200 = 192.168.6.0/24
access-list 101 permit ip any 192.168.5.0 0.0.0.255
access-list 102 permit ip any 192.168.6.0 0.0.0.255
route-map PBR permit 10
match ip address 101
set interface vlan100
route-map PBR permit 20
match ip address 102
set interface vlan 200
note if vlan 100 and 200 are not interfaces on router then you can use "set ip next-hop " and "set ip next-hop " instead of "set interface commands.
You will also need to apply the route-map to the T1 interfaces eg.
int s0/0
ip policy route-map PBR
Jon
