Disable routing on two phyiscal interfaces?
starmantwo
I have a 2811 with 2 fe interfaces. Im looking to disable routing between them.
But also have routing enable. Would i use a "ip vrf" config for this?
spremkumar
Level 9
Level 9
You can put them under different VRF's so that you make them different routing zones altogether...
regds
