Disable SSLv3 on Switch 3650
Hi!
I need to disable SSLv3 on my switches 3650 so my customer can access the wireless gui through https (with firefox/chrome).
Concern this, my customer really doesn't need to use https; but since I added the 3650 switches to Prime Infrastructure, it enables HTTPS and disable HTTP on every single switch.
So my issue can be solved by:
Disabling SSLv3 or Disabling the feature in Prime Inf. that enables https on every switch after syncing.
For all your attention and future help, thank you so much.
Best Regards!
0 Replies 0
