Disabling smart install on 3750 stack switch
mahesh18
Level 7
Level 7
Hi Everyone,
Need to know on 3750 switch which has 2 stack memebers
Model WS-C3750G-24T"
sh switch
Switch/Stack Mac Address : 0018.198b.9e80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0018.198b.9e80     1      0       Ready
2       Member 001a.6d5b.e180     1      0       Ready
currently it has smart install feature configured
sh vstack config
Role: Client (SmartInstall enabled)
Vstack Director IP address: 0.0.0.0
*** Following configurations will be effective only on director ***
Vstack default management vlan: 1
Vstack management Vlans: none
Join Window Details:
         Window: Open (default)
         Operation Mode: auto (default)
Vstack Backup Details:
         Mode: On (default)
         Repository:
Need to know if it is safe to disable the smartinstall feature in production environment?
What does smart install do?
Reason i need to do this is due to security threat as per link below
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20130327-smartinstall
MAhesh
2 Accepted Solutions
Leo Laohoo
No IP address for VStack so this means VStack is not configured or enabled.  Post the output to the commnand "sh run | i vstack".  If there are no output, then VStack is not really enabled.
Can you please tell what does smart install do in nutshell?
Funny you should ask.  I wrote a blog about it last year.  Have a read when you have the time.
How to use Zero-Touch SmartInstall
PS:  Thanks for taking the time to rate our posts, Mahesh.
10 Replies 10
Leo Laohoo
Hi Leo,
I run  the command  there is no output.
MAhesh
Hi Leo,
I read the above article which was very good.
Thanks for Excellent work and helping the community.
Mahesh
Thanks, Mahesh.
I hope the blog will be able to help you in the future.
I tried to access this article for some reason when I login with my cco tells me I can't access it.
izzy
Smart Install is enabled default, so you do not see any config for that!
sh vstack config
-> you see
Role: Client
I have the problem on some switches to disable it with
no vstack
command because the switch does know this command but "sh vstack config" shows the role "client"
Switch: WS-C2960G-48TC-L
Software: Version 12.2(52)SE
Can some one tell me how I can disable Smart Install on this switch?
You have to run the "no vstack" command under "Configure Terminal (conf t)"
Hello Leo,
I also have a 3750 switch stack with 4 switchs and have the same issue.
I see Vstack Director IP address: 0.0.0.0, but if I check my running config I get output.
From your post if we don't have a director configured "Vstack Director IP address: 0.0.0.0" we can safely disable vstack on a cisco switch stack production environment safely?
gigaswitch02#sh run | i vstack
vstack
gigaswitch02#show vstack config
 Capability: Director | Client
 Oper Mode: Enabled
 Role: Client
 Vstack start-up management vlan: 1
         Mode: On (default)
         Repository:
David Costa
jlopezbo
To disable smart install feature . If the switches are already install and you will not use smart install there is not any problem to disable this feature
Example
switch#show vstack config
Role: Client (SmartInstall enabled)  >>>>>>>>>>>>(it's enable by default)
         Mode: On (default)
         Repository:
switch#conf ter
switch(config)#no vstack >>>>> Run the command to disable smart install
switch(config)#do show vstack confi
Role: Client (SmartInstall disabled) >>>>>>>>>>> Then the smart install got disable
         Mode: On (default)
         Repository:
WS-C2960X-24PS-L-SW1(config)#
