Disappearing Printer
Farls999
Frequent Visitor
Frequent Visitor
I have a printer that will appear for 3-5 pings after the port is bounced, then it disappears.  I have removed all port security config from the port, upgraded the switch to newer iOS, and rebooted it.    Printer works if we remove the phone from the equation.  Port was never in err-disabled state (always up and up).  No port security violations.  Cables tested good.
What is the next step in troubleshooting this problem?  I do not have physical access to the access switch or printer.
Details:
Distrib Switch (4507R+E) -> Access Switch (c3560x Poer 0/10) -> Phone (7911) -> Printer (192.168.62.15)
Access Port Config:
interface GigabitEthernet0/10
switchport access vlan 62
switchport mode access
switchport voice vlan 162
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AutoQoS-Police-CiscoPhone
end
Immediately after bouncing the port:
 ColdRoom#sh mac address-table | i 0/10
  62    001b.2a1f.f097    DYNAMIC     Gi0/10
  62    40b0.3472.a8b4    DYNAMIC     Gi0/10
 162    001b.2a1f.f097    DYNAMIC     Gi0/10
ColdRoom#
4507R#sh mac address-table
62 40b0.3472.a8b4 dynamic ip,ipx,assigned,other GigabitEthernet1/4
162 001b.2a1f.f097 dynamic ip,ipx,assigned,other GigabitEthernet1/4
 4507R#
c:\ping 192.168.62.15 -t
Request timed out.
Request timed out.
Reply from 192.168.62.15: bytes=32 time<1ms TTL=63
Request timed out.
Request timed out.
After a few minutes:
4507R#sh mac address-table | i f097
4507R#sh mac address-table | i a8b4
 4507R#
Thank you for your time!
Reza Sharifi
Can you hard set the port and the printer's NIC and test again?
Sorry for the delay - I do not have physical access to the printer and phone, so it took some time to get someone over there.
Hard setting the printer's NIC did not work.  Both the port and the printer are now set to 100/Full.   The phone came up but the printer never did.  Now when I bounce the port I do not receive the 3 to 5 successful pings.
*Edited for spelling
