Discrepancy between input and output rates on SPAN interfaces
dbsga
Just trying to understand why there is a consistent ~50% discrepancy between the input data rate of the SPAN source interface and the output data rate of the SPAN destination interface?
Input/output rates seem to align for another monitor session running on the same switch.
Any insight would be greatly appreciated! Thanks.
Interface statistics shown below.
IE-4010-16S12P :  15.2(6)E1
Session 2
Type : Local Session
Source Ports :
RX Only : Gi1/18
Destination Ports : Gi1/5
Encapsulation : Replicate
Ingress : Disabled
GigabitEthernet1/18 is up, line protocol is up (connected)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 23/255
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 91800000 bits/sec, 67763 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
9514123310 packets input, 1258153953541 bytes, 0 no buffer
Received 24381626 broadcasts (18445610 multicasts)
1 runts, 0 giants, 0 throttles
4 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 18445610 multicast, 0 pause input
371296 packets output, 29977348 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
19721 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet1/5 is up, line protocol is down (monitoring)
reliability 255/255, txload 12/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Last input never, output 1d17h, output hang never
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 49269000 bits/sec, 63367 packets/sec
218 packets input, 47131 bytes, 0 no buffer
Received 218 broadcasts (172 multicasts)
0 watchdog, 172 multicast, 0 pause input
9100945063 packets output, 864557186870 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
andrewswanson
Level 7
Level 7
From the Cisco Documentation:
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie4010/software/release/15-2_4_EC/configuration/guide/scg-ie4010_5000/swspan.html
Multicast traffic can be monitored. For egress and ingress port monitoring, only a single unedited packet is sent to the SPAN destination port. It does not reflect the number of times the multicast packet is sent.
Does the other SPAN session (with similar i/o rates) have the same level of multicast?
hth
Andy
