02-20-2015 12:55 AM - edited 03-07-2019 10:45 PM
Hi everybody,
I've the following configuration: CISCO 881, IOS 15.2(4)M6. On WAN interface is configured the 86.34.156.48/29 subnet from our ISP. Behind the router is staying 2 webserver. NAT: 86.34.156.51 <> 10.10.10.100 (private IP, server1). If I configure the BIND DNS server A records with the external IP of the server(86.34.156.51) the outside world never get the response from my DNS server(I don't know what happens there, perhaps the router does DNS doctoring or something similar ( it is a question)), and it is sure the DNS server is configured and works properly(I captured the IP packets with TCPdump). But if I configure the DNS server A records with the server private IP (10.10.10.100) the packets is alwasy arriving to proper destination(with the server external IP, perhaps DNS doctoring too). The only one problem with this is, that the DNS packet TTL value disappear, as you can see in the below digs output.
What could I do?
| | an other host somewhere on internet(C)
: internet
| | ISP's router
| | black box, without acces
| 86.34.456.48/29
| | CISCO 881,
| | IOS 15.2(4)M6
------------------------------------------------------------ local private network 10.10.10.0/24
| (86.34.156.51) | (Nat rule not yet attached)
| 10.10.10.100 | 10.10.10.101
linux server (A) linux server (B)
BIND DNS server
style2take.ro
Here is some dig (dns diagnostic tool under linux):
From host B : $dig style2take.ro
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 42222
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;style2take.ro. IN A
;; ANSWER SECTION:
style2take.ro. 0 IN A 10.10.10.100 <-- here you can see the TTL is 0
;; Query time: 52 msec
;; SERVER: 193.231.100.130#53(193.231.100.130)
;; WHEN: Fri Feb 20 10:27:25 EET 2015
;; MSG SIZE rcvd: 58
From host B: $dig @10.10.10.100 style2take.ro
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 65374
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 3
;; WARNING: recursion requested but not available
;; ANSWER SECTION:
style2take.ro. 3600 IN A 10.10.10.100 <-- here you can see the TTL is 3600
;; AUTHORITY SECTION:
style2take.ro. 3600 IN NS ns1.style2take.ro.
style2take.ro. 3600 IN NS ns2.style2take.ro.
;; ADDITIONAL SECTION:
ns1.style2take.ro. 3600 IN A 10.10.10.100
ns2.style2take.ro. 3600 IN A 10.10.10.100
;; Query time: 0 msec
;; SERVER: 10.10.10.100#53(10.10.10.100)
;; WHEN: Fri Feb 20 10:28:58 EET 2015
;; MSG SIZE rcvd: 126
From host C : $dig style2take.ro
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32364
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 6, ADDITIONAL: 0
;; ANSWER SECTION:
style2take.ro. 0 IN A 86.34.156.51 <-- here you can see the TTL is 0
ro. 106161 IN NS sns-pb.isc.org.
ro. 106161 IN NS primary.rotld.ro.
ro. 106161 IN NS sec-dns-a.rotld.ro.
ro. 106161 IN NS sec-dns-b.rotld.ro.
ro. 106161 IN NS dns-at.rotld.ro.
ro. 106161 IN NS dns-ro.denic.de.
;; Query time: 149 msec
;; SERVER: 82.79.24.74#53(82.79.24.74)
;; WHEN: Fri Feb 20 10:29:52 2015
;; MSG SIZE rcvd: 201
From host C: $dig @86.34.156.51 style2take.ro
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 48385
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 2
;; ANSWER SECTION:
style2take.ro. 0 IN NS ns2.style2take.ro.
style2take.ro. 0 IN NS ns1.style2take.ro.
ns1.style2take.ro. 0 IN A 86.34.156.51
ns2.style2take.ro. 0 IN A 86.34.156.51
;; Query time: 29 msec
;; SERVER: 86.34.156.51#53(86.34.156.51)
;; WHEN: Fri Feb 20 10:35:05 2015
;; MSG SIZE rcvd: 115
