DNS Problem
Smithers944
Community Member
I am having a problem with the dns setup on my router(851w)
when I point my clients to my router for dns resolutions (200.0.0.1) they don't get resolved..., so my solution was to point them to an actual dns server of my isp (203.12.160.36) via a static route to my adsl interface (Dialer2) But that's an abnormal way to do it...
How do I setup my router so i can just point my clients to my router (200.0.0.1) for dns resolutions. Any help is much appreciated.
My router's config is below:
SMITTY_ROUTER(config)#do sh run
Building configuration...
Current configuration : 4098 bytes
version 12.4
no service pad
service password-encryption
hostname SMITTY_ROUTER
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$X2p6$X0xMR7mBvuaAUlCueTxys1
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 200.0.0.1 200.0.0.9
ip dhcp pool DHCP
   import all
   network 200.0.0.0 255.255.255.224
   dns-server 203.12.160.36 203.12.160.35
   default-router 200.0.0.1
   lease 4
ip cef
ip domain name SmitNet.com
ip name-server 203.12.160.36
ip name-server 203.12.160.35
ip rcmd rcp-enable
ip rcmd remote-host sdmRd8ec55b8 200.0.0.22 Ld8ec55b8 enable
ip rcmd remote-username sdmRd8ec55b8
vpdn enable
crypto pki trustpoint TP-self-signed-3874658233
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3874658233
revocation-check none
rsakeypair TP-self-signed-3874658233
crypto pki certificate chain TP-self-signed-3874658233
certificate self-signed 01
  30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383734 36353832 3333301E 170D3032 30343033 32303439
  32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38373436
  35383233 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100ACF6 701F3FD2 BD47B5D8 841A0481 1D426E4A FF604C29 B0B0AD35 F5CD465F
  CABB574E 743E78E4 6BA16C22 BF70640E B7A576E6 DC7E13DD D9FD9269 97B1DDC9
  33EA7E4F 797C078C 5E8B826D F667BA77 B0E1667D 5857A2D0 84BD1266 026DA565
  D96922CE 4100D415 23D0E3C9 600E31D7 7FF28AE3 4BC4FA18 63766218 749E2303
  116D0203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 19534D49 5454595F 524F5554 45522E53 6D69744E 65742E63
  6F6D301F 0603551D 23041830 168014D3 6BE62F4E 7AC4CE7B 7F678526 B4F22179
  BDCFF730 1D060355 1D0E0416 0414D36B E62F4E7A C4CE7B7F 678526B4 F22179BD
  CFF7300D 06092A86 4886F70D 01010405 00038181 0003CED9 C6DAAD3A 767D0AC0
  765A8930 FBB2D7D5 9AD884F1 01C43B4B 17C62AFC DD940FA3 D3C65A1D 2A688759
  128D6CE3 38F18F16 DADC5EB0 99739D32 34ABDC1B E417EEB8 9AFF560E A2D0C72C
  704ADC11 CFADEA54 A7BC5AC1 DFC87B44 72634197 38A0F457 6EAB6124 1BC18052
  5AD5E082 3B81302D 7EBB9BD6 46501E4A 265C7485 1A
  quit
username david privilege 15 secret 5 $1$BbPR$5NamnAITOZonmIlrCxEaB1
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
pppoe enable
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ip nat inside
ip virtual-reassembly
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
ip address 201.0.0.2 255.255.255.224
shutdown
no snmp trap link-status
no cdp enable
interface Vlan1
ip address 200.0.0.1 255.255.255.224
ip nat inside
ip tcp adjust-mss 1412
interface Dialer2
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username louisepr password 7 111D09024640585851
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer2
ip http server
ip http secure-server
ip nat inside source list 2 interface Dialer2 overload
access-list 1 permit 200.0.0.0 0.0.0.31
access-list 2 remark INSIDE_IF=Vlan1
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 200.0.0.0 0.0.0.31
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CSMITTY ROUTER !!!!!!!!!!!!!^C
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
login local
transport input all
scheduler max-task-time 5000
end
8 Replies 8
   Can you configure the following command(if supported) on C851w?
SMITTY_ROUTER(conf)#ip dns server
HTH,
Toshi
johnlloyd_13
Level 11
Level 11
Hi David,
Your current config (via DHCP) already did meet your objective.
Hi John,
I don't think so because he wants his Cisco gear to act like a forwarding DNS and in the DHCP snippet the DNS servers are external but that is the config working but not the one he wants.
He need 3 things:
-in DHCP scope use the router IP as DNS server
-add ip dns server  like Toshi remarked
-add the ip addresses of the external DNS with ip name server command in global config
Regards.
Alain.
Yes Cadet thats what I want. I tried the steps above but the "ip dns server" command does not exist on my router.
I have these other commands
ip domain
ip domain-list
ip domain-lookup
ip domain-name.
Can I use these other commands instead?
Thanks for the replies.
Use
ip domain-lookup
What version of IOS are you running?  The 'ip dns server' command that cadet suggested should be the winner here, but are you certain that it doesn not work? Try
Router(config)# ip d?
Message was edited by: Antonio Knox
ip domain-lookup is the default that's why I didn't mention it but is is mandatory.
for the Proxy DNS support ( ip dns server) you need an advanced security image  > 12.3
Regards.
Alain
Alain is right.
Smithers944
Community Member
Thank you everyone,
I upgraded my iOS to the latest version and enabled the "ip dns server" command. Everything works perfectly now.
Many many thanks ❤️
