Do Cisco routers come with console cables?
Bob Smith
I just purchased several Cisco 891W routers and I was wondering if they came with console cables (i.e. DB-9 to RJ-45)? Or is this something I have to purchase seperately?
Leo Laohoo
For the 860/880/890 and the rest of the ISR G2's, console cables (whether is the traditional or USB) is "optional".
Same goes with 2960S, 3750X and 3560X.
cadet alain
You can make your own with cat 5 utp.
http://www.alliancedatacom.com/manufacturers/cisco-systems/connector_cables/cable_pinouts.asp
Regards.
Alain.
sylvain.munaut
Note that the newer ISR G2 have a 'usb' console (it's essentially a USB -> Serial adapter right in the router) and so you can use any USB -> USB mini cable. The console is recognized as a normal 'usb serial' device (/dev/ttyACM0 on linux).
