Do the 3560X switches include StackWise cables
pascal
Level 3
Level 3
When purchasing part number WS-C3560X-48P-L is a StackWise cable included or do I need to purchase that separately?
Reza Sharifi
The cable comes with the package.  It is in the box when you get the switch
Reza Sharifi
the 3560 is not stackable only 3750 (It comes in the box)
Marvin Rhoads
The 3750X stackable switches come with a 0.5m StackWise cable by default.
Both the old style 3560 and newer 3560X switches are not stackable
See the hardware installation guide here which states:
The Catalyst 3750-X switches support stacking through Cisco StackWise technology and power management through StackPower. The Catalyst 3560-X switches do not support switch stacking or StackPower.
and
Length of cable. Depending on the configurations that you have, you might need different-sized cables. If you do not specify the length of the StackWise cable, the 0.5-meter cable is supplied. If you need the 1-meter cable or the 3-meter cable, you can order it from your Cisco supplier. For cable part numbers, see the "StackWise Ports" section on page 1-19 . The "Data Stack Cabling Configurations" section provides examples of recommended configurations.
Hope this helps.
