07-08-2017 06:11 PM - edited 03-08-2019 11:15 AM
hello guys everything is in the title ,i got confused from some videos saying that we have to put a interface in the management vlan and some saying that just adding a no shut in the svi is enough ..................... what's the truth ? and how to use the management vlan in the lan and remotely ?
THANKS
07-08-2017 06:30 PM
An SVI will work just if the vlan is created and if it is associated to an access port or on trunk interface, usually the vlan associated to the SVI pass through the trunk interface connected to the distribution or core switch.
Your configuration should be:
Example:
vlan 100
name MANAGEMENT
interface vlan 100
name MANAGEMENT
ip address 192.168.100.10 255.255.255.0
no shutdown
ip default-gateway 192.168.100.1 <--- the default gateway of the network associated to the vlan 10, it is usually created on the distribution or core switch or router. Also this command line will allow you to reach the device remotely through the management SVI.
interface g1/1/1
description TO-DISTRIBUTION-SW
switchport mode trunk
no shutdown
*As Im not filtering vlans under the trunk interface, all the vlans are passing through by default, you can see that executing: show interface trunk.
Hope it is useful
07-09-2017 09:14 AM
thanks
but i don't get it you didn't associate any interface to the management vlan in your example , why ?
i understand for the trunk connection it's quite obvious that without it traffic will not pass , but still you said associate a trunk port ! a trunk port is part o the native vlan how can i associate it with a management vlan then ? , or do you mean something else by "associate" ?
i still don't understand if i should add a interface to the svi or not and why ?
thanks for your time
07-09-2017 09:17 AM
Yes you should create an SVI for the management vlan so you can connect remotely to the switch.
You don't assign a port to that vlan, you use a trunk link and the management vlan is allowed on that link.
Jon
07-10-2017 05:51 PM
what if i assign a interface to that management vlan , does it means that the management vlan will only be accessible on that link ?
07-10-2017 06:05 PM
Nop, usually in order to activate a interface vlan, the vlan must be created and it must be associated to an access port or pass the vlan under a trunk, in this case for the management interface vlan you only need to pass the vlan under the trunk.
The management vlan must not be associated or configured under any access port for security purposes.
The idea with the management vlan is be able to manage the switches remotely using telnet or SSH.
07-10-2017 07:09 PM
what do you mean by associate with a trunk or a access ports ? what i mean to do is
interface vlan 88
ip address 192.168.88.1 255.255.255.0
no shut
here the vlan is activated in all ports and the switch configured from each pc
interface fast 0/1
switchport access vlan 88
does the vlan work only from the interface 0/1 ?
now this switch can only be telneted by a pc connected with the interface fast 0/1
is this correct and if not what should happen ?
07-10-2017 07:25 PM
For example, if you create the vlan 88 and the interface vlan 88 as well but if it is not associated an interface example fa0/1 or passing through over a trunk interface, the interface vlan (SVI) will be displayed as up down through show ip interface brief.
But it is not the case with the management vlan, because a good practice is not associate the management vlan to any interface working as access mode.
For example your configuration for the management vlan should be:
Access switch
vlan 88
name MANAGEMENT
interface vlan 88
description MANAGEMENT
192.168.88.10 255.255.255.0
no shutdown
ip default-gateway 192.168.88.1
interface fa1/48
no shutdown
*By default all the vlans are passing through the trunk interfaces unless you are filtering them.
