Do we need to use ACL command before using route filtering method in B
krahulbgp
Do we need to use ACL command before using route filtering method in Bgp?
BGP update contain
prefix <- you can use ACL or prefix-list with route-map to match it
attribute <- here you can match any attribute appear in update with route-map
so not always you need ACL
balaji.bandi
yes that is the order of operation, with out ACL name, you getting if that is not exists in the syste,
BB
Thanks sir
