Do you think the interface BW is normal in C3560
eigrpy
Level 4
Level 4
Hi, Do you think the interface BW is normal in C3560. The switch has 24 fast ports and 2 giga ports. The giga port' BW is 10000 Kbit, while fast port BW is 100000 Kbit. What can cause the issue? The below is output of interface, Thank you
Switch   Ports      Model                    SW Version              SW Image
*    1      26     WS-C3560-24PS      12.2(25)SEE2            C3560-IPBASEK9-M
Switch#sh int gigabitEthernet 0/2
GigabitEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0019.56b4.cd02 (bia 0019.56b4.cd02)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is Not Present
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Switch#sh interfaces fastEthernet 0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.56b4.cd03 (bia 0019.56b4.cd03)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
Last input 00:01:59, output 00:00:00, output hang never
5 minute output rate 1000 bits/sec, 1 packets/sec
77 packets input, 6737 bytes, 0 no buffer
Received 77 broadcasts (0 multicast)
0 watchdog, 73 multicast, 0 pause input
142 packets output, 10954 bytes, 0 underruns
--More--
6 Replies 6
Peter Paluch
On Ethernet-type interfaces, switches automatically adjust their reported bandwidth depending on the result of autonegotiation, that is, the speed the port has negotiated with its link partner. Obviously, a port that is down/down is treated as a 10Mbps port (the slowest Ethernet available), hence the reported bandwidth. As the FastEthernet port has negotiated 100Mbps operation with its link partner, the reported bandwidth also corresponds to 100Mbps.
The bandwidth indication on a Gigabit Ethernet port (or any Ethernet port for that matter) will make sense only when the port is up/up, and it will correspond to the negotiated speed.
Best regards,
Peter
Thank you so much for your reply. If I want to know the physical speed of the port, how can I know that? Is the BW could be its speed ? Thank you
With Ethernet-type interfaces, the maximum supported speed can be directly inferred from the name of the interface:
  • Ethernet: 10 Mbps
  • FastEthernet: 10/100 Mbps
  • GigabitEthernet: 10/100/1000 Mbps
  • TenGigabitEthernet: 10/100/1000/10000 Mbps
On switches, you can also use the show interface interface-name capabilities command to find out about the interface capabilities including supported port speeds:
Switch# show interface gi0/1 capabilities
GigabitEthernet0/1
  Model:                 WS-C3560G-48TS
  Type:                  10/100/1000BaseTX
  Speed:                 10,100,1000,auto
  Duplex:                half,full,auto
  Trunk encap. type:     802.1Q,ISL
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
On copper (twisted pair) interfaces, the interface usually supports all speeds from 10 Mbps up to its maximum speed, and the real communication speed will depend on the capabilities of the link partner advertised during the autonegotiation. On fiber interfaces, usually only a single speed is supported and it cannot be autonegotiated. This is because optical transceivers are usually constructed for only a single supported speed.
Best regards,
Peter
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
When port is up, it should indicate physical speed/bandwidth.
For example, from your original post:
--More--
Adding to my previous comment.
It is the default output of show interface fa0/0
Hardware is Lance, address is 0060.4706.d201 (bia 0060.4706.d201)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Half-duplex, 100Mb/s
I changed the speed of the interface from 100 to 10 by speed command. As you see, bandwidth is changed because bandwidth is calculated by speed; however, it is unrelated to the actual bandwidth. you can change it to 1 as I did in my previous comment. It does not have effect on actual bandwitdh.
Half-duplex, 10Mb/s
input flow-control is off, output flow-control is off
Masoud
Bandwitdh and speed are different on the interface. Default bandwidth is calculated based on the interface speed or you can change it by "Bandwidth command" under the interface. BW does not have to do anything with actual bandwidth on the interface. Check  the output below. I have changed bandwidth to 1, but still able to transfer much more on the interface. Check the 5 minutes input/output rate. It shows the current bandwitdh(average in 5 minutes).
FastEthernet0/0 is up, line protocol is up
  Hardware is DEC21140, address is ca01.03c0.0000 (bia ca01.03c0.0000)
  Internet address is 1.1.1.1/24
  MTU 1500 bytes, BW 1 Kbit, DLY 100 usec,
     reliability 255/255, txload 204/255, rxload 204/255
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:03, output 00:00:03, output hang never
  5 minute input rate 2135000 bits/sec, 201 packets/sec
  5 minute output rate 2134000 bits/sec, 201 packets/sec
     106442 packets input, 155351022 bytes
     Received 20 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     106540 packets output, 155356902 bytes, 0 underruns
Speed is the max speed that interface supoprts depending on the auto negotiation and BW is used for routing protocol to find the best path toward a destination.
Hope it helps,
Masoud
