Does C9300-48U support multigig?
Michael Murray
Level 5
Level 5
Can anyone tell me if the C9300-48U switch supports multigig or is it just the "X" models for the 9300s? I can't tell from the datasheet.
-mike
2 Accepted Solutions
Mark Malone
Hi data sheets shows these models support it
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/data_sheet-c78-738977.html
C9300-48U
48 Cisco UPOE
1100W AC
822W
Yes
Yes
C9300-24UX
24 Multigigabit Cisco UPOE (100M, 1G, 2.5G, 5G, or 10 Gbps)
1100W AC
560W
Yes
Yes
C9300-48UXM
36x 100 Mbps,1G, 2.5G + 12x Multigigabit (100M, 1G, 2.5G, 5G, or 10 Gbps)
1100W AC
490W
Yes
Yes
C9300-48UN
48x 5 Gbps UPOE ports (100M, 1G, 2.5G, 5G)
1100W AC
645W
Yes
Yes
Leo Laohoo
6 Replies 6
Mark Malone
C9300-48U
48 Cisco UPOE
1100W AC
822W
Yes
Yes
C9300-24UX
1100W AC
560W
Yes
Yes
C9300-48UXM
1100W AC
490W
Yes
Yes
C9300-48UN
1100W AC
645W
Yes
Yes
Thanks. So that does include the c9300-48u model then? The other models explicitly say multigig but this one doesn’t even my though it lists 2.5 and 5 so I’m confused.
If it doesnt say it i wouldnt chance it from previous experience but your reseller should be able to tell you too , you could push it back on him but to me looks like standard U is not multi gig while UX and UN are , data sheets to be fairly accurate for hardware specifics in fairness to Cisco
Leo Laohoo
Nope. Only uPoE.
How about C9300-48UN - 48x 5 Gbps UPOE ports (100M, 1G, 2.5G, 5G)?
Exactly what devices do you have that requires mGIG?
And will you need mGIG 10 (Gbps) or is 5 Gbps enough?
Next, how many mGIG ports do you want? Particularly in the 48-port variety, the data sheet gives anyone the impression that ALL ports support mGIG when there are only a few ports will support 10 Gbps, 5 Gbps.
