Does it possible ASA 5512-X with Switch 2960 (Inter-Vlan)
chhayheng
Dear Everyone!!
(Cisco 5512-X)
interface GigabitEthernet0/0
 description Intranet
 speed 100
 duplex full
 nameif inside
 security-level 0
 ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/1
 speed 100
 duplex full
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/1.101
 description NAC_DR
 vlan 101
 nameif nac_prod
 security-level 80
 ip address 21.20.20.1 255.255.255.0
interface GigabitEthernet0/1.201
 description NAC_UAT
 vlan 201
 nameif nac_uat
 security-level 60
 ip address 22.20.20.1 255.255.255.0
SWITCH (2960)
interface range FastEthernet0/1 - 12
 switchport mode access
 switchport access vlan 101
interface range FastEthernet0/13 - 23
 switchport access vlan 201
interface FastEthernet0/24
 description To Firewall
 switchport mode trunk
 load-interval 30
 speed 100
 duplex full
What is the problem ?
2 Accepted Solutions
The main problem is, that you don't ask a question ... ;-)
So, which problem do you have?
Is it only ping that fails or also other traffic? Have you enabled icmp-inspection on the ASA?
Which addresses do you ping from which device?
8 Replies 8
Hello Karsten :)
I have to configure Inter-Vlan between ASA 5512-X with Cisco Switch 2960.
When I ping from one vlan to other vlan it not reach each other.
Best Regards,
Chhayheng
I already applied icmp-inspection.
I want to ping from IP 21.20.20.1 to 22.20.20.1 .
These are the addresses of your ASA. Ping from a system in the connected LAN to a system on the other LAN.
And do a packet-tracer to see what the ASA would do with the traffic. Perhaps it's missing/wrong access-control or NAT:
packet-tracer input nac_prod icmp 21.20.20.x 8 0 22.20.20.x
One more thing. I do research on google about InterVlan (ASA work with switch layer 2 ). Does it possible to configure inter-vlan between ASA5512-X with Layer2 Switch ?
The result:
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Result:
input-interface: nac_prod
input-status: up
input-line-status: up
Action: drop
Drop-reason: (no-route) No route to host
Yes, the ASA can be used for inter-vlan-routing. That's a quite common implementation.
But your packet-tracer shows that you probably used the command with wrong addresses. With directly connected interfaces, there can't be a route missing. You probably entered an address that was remote to the ASA.
I already fixed it by some question
First: ACL
Second: If the same security level (Allow the same-security)
Best Regards,
Chhhayheng
