does LAN_Base IOS support SSO in L2 4507?
dahua.huang
We will deploy several 4507 with 2xsup7 as a L2 access switches for our office.
Does LAN_Base IOS version support SSO or we need purchase IP_Base IOS (L3)?
Thanks.
mvsheik123
Level 7
Level 7
Per Cisco doc, SSO is supported in Cisco IOS Release 12.2(20)EWA and later releases. Lan base & IP base /advanced etc - mainly determine supported advanced features such as advance routing etc. As long as you have the recomended version you are good to go. Check the below link ...
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/RPR.pdf
hth
MS
