Domain-based and NVI based NAT Question
Evgeny777
Cisco 2811; IOS 124-24.T5
The ping goes from two hosts, A and B, at the same time to the same address.
Domain-based NAT config (OK):
interface FastEthernet0/0
  ip address 10.5.171.11 255.255.255.0
no ip redirects
no ip proxy-arp
ip nbar protocol-discovery
ip nat inside
ip virtual-reassembly
no ip mroute-cache
  no cdp enable
interface FastEthernet0/0/0.41
description --------------                                iDirect Management
encapsulation dot1Q 41
ip address 10.147.0.1 255.255.255.240
no ip redirects
no ip proxy-arp
ip nat outside
no ip mroute-cache
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.5.171.1
ip nat inside source list iDirect_NMS interface FastEthernet0/0/0.41 overload
ip access-list extended iDirect_NMS
deny   udp any any eq 0
deny   tcp any any eq 0
permit ip 10.5.7.0 0.0.0.255 10.147.0.0 0.0.0.15
permit ip 192.168.3.0 0.0.0.255 10.147.0.0 0.0.0.15
deny   ip any any
ip nat detailed debug output:
Host A
May 24 10:30:20:  mapping pointer available mapping:0
May 24 10:30:20: NAT: [0] Allocated Port for 192.168.3.34 -> 10.147.0.1: wanted 512 got 512
May 24 10:30:20: NAT*: i: icmp (192.168.3.34, 512) -> (10.147.0.2, 512) [25128]
May 24 10:30:20: NAT*: s=192.168.3.34->10.147.0.1, d=10.147.0.2 [25128]
May 24 10:30:20: NAT*: o: icmp (10.147.0.2, 512) -> (10.147.0.1, 512) [10628]
Host B
May 24 10:30:32:  mapping pointer available mapping:0
May 24 10:30:32: NAT: [0] Allocated Port for 10.5.7.32 -> 10.147.0.1: wanted 512 got 514
May 24 10:30:32: NAT*: i: icmp (10.5.7.32, 512) -> (10.147.0.2, 512) [10044]
May 24 10:30:32: NAT*: ICMP id=512->514
May 24 10:30:32: NAT*: s=10.5.7.32->10.147.0.1, d=10.147.0.2 [10044]
May 24 10:30:32: NAT: o: icmp (10.147.0.2, 514) -> (10.147.0.1, 514) [10633]
May 24 10:30:32: NAT: ICMP id=514->512
May 24 10:30:32: NAT: s=10.147.0.2, d=10.147.0.1->10.5.7.32 [10633]
NVI based NAT (Not OK)
no ip redirects
no ip proxy-arp
ip nat enable
no ip mroute-cache
duplex auto
speed auto
no cdp enable
  no ip redirects
no ip proxy-arp
ip nat enable
no cdp enable
ip nat source list iDirect_NMS interface FastEthernet0/0/0.41 overload
deny   ip any any
Host A
May 24 10:34:38: NAT: creating portlist proto 1 globaladdr 10.147.0.1
May 24 10:34:38: NAT: [0] Allocated Port for 192.168.3.34 -> 10.147.0.1: wanted 512 got 512
May 24 10:34:38: NAT*: i: icmp (192.168.3.34, 512) -> (10.147.0.2, 512) [5800]
May 24 10:34:38: NAT*: s=192.168.3.34->10.147.0.1, d=10.147.0.2 [5800]
May 24 10:34:38: NAT: i: icmp (10.147.0.2, 512) -> (10.147.0.1, 512) [10639]
May 24 10:34:38: NAT: s=10.147.0.2, d=10.147.0.1->192.168.3.34 [10639]
Host B
May 24 10:34:50: NAT: [0] Allocated Port for 10.5.7.32 -> 10.147.0.1: wanted 512 got 513
May 24 10:34:50: NAT*: i: icmp (10.5.7.32, 512) -> (10.147.0.2, 512) [10900]
May 24 10:34:50: NAT*: s=10.5.7.32->10.147.0.1, d=10.147.0.2 [10900]
May 24 10:34:50: NAT: i: icmp (10.147.0.2, 512) -> (10.147.0.1, 512) [10644]
May 24 10:34:50: NAT: s=10.147.0.2, d=10.147.0.1->192.168.3.34 [10644]
Florin Barhala
Level 6
Level 6
Weirdo; it should be sourced with 10.147.0.1, right?
I believe the last line should look like:
