Dose Cisco Catalyst Blade Switch 3020 for HP is supporting MEC ?
narayanan_b
Dear all,
I would like to  configure MEC from  Cisco Cat Blade Switch 3020 for HP using 4 X 1G UTP  to  VSS enable Cisco Cat 6506 Switch. Two links will be on Core-Switch1 and 2 links will on Core-Switch-2. Is  this will work ? Can you please help me by providing configuration.
Thanks and Regards,
Narayanan
Leo Laohoo
Yes this is achievable.
Reza Sharifi
As Leo also said that can be done
The 3020 switches can also be stacked inside the chassis just like the 3750s
