%DOT1X-5-FAIL: Authentication failed for client
I have the following problem to configure 802.1x.
Deubug shows the following:
Nov  6 16:44:55.732: RADIUS/ENCODE(00000095):Orig. component type = Exec
Nov  6 16:44:55.732: RADIUS(00000095): Config NAS IP: 10.100.52.10
Nov  6 16:44:55.732: RADIUS(00000095): Config NAS IPv6: ::
Nov  6 16:44:55.732: RADIUS(00000095): sending
Nov  6 16:44:55.732: RADIUS(00000095): Sending a IPv4 Radius Packet
Nov  6 16:44:55.732: RADIUS(00000095): Send Accounting-Request to 10.95.1.114:1813 id 1646/16,len 90
Nov  6 16:44:55.732: RADIUS:  authenticator 79 25 BD 80 67 D6 1F BA - 5E 02 2B 55 98 37 69 BF
Nov  6 16:44:55.732: RADIUS:  Acct-Session-Id     [44]  10  "0000008B"
Nov  6 16:44:55.735: RADIUS:  Acct-Authentic      [45]  6   Local                     [2]
Nov  6 16:44:55.735: RADIUS:  Acct-Terminate-Cause[49]  6   user-request              [1]
Nov  6 16:44:55.735: RADIUS:  Acct-Session-Time   [46]  6   2280
Nov  6 16:44:55.735: RADIUS:  Acct-Status-Type    [40]  6   Stop                      [2]
Nov  6 16:44:55.735: RADIUS:  NAS-Port            [5]   6   0
Nov  6 16:44:55.735: RADIUS:  NAS-Port-Id         [87]  6   "tty0"
Nov  6 16:44:55.735: RADIUS:  NAS-Port-Type       [61]  6   Async                     [0]
Nov  6 16:44:55.735: RADIUS:  Service-Type        [6]   6   NAS Prompt                [7]
Nov  6 16:44:55.735: RADIUS:  NAS-IP-Address      [4]   6   10.100.52.10
Nov  6 16:44:55.735: RADIUS:  Acct-Delay-Time     [41]  6   0
Nov  6 16:44:55.735: RADIUS(00000095): Started 5 sec timeout
Nov  6 16:44:55.735: RADIUS: Received from id 1646/16 10.95.1.114:1813, Accounting-response, len 20
Nov  6 16:44:55.735: RADIUS:  authenticator AC C0 5B 5B 04 B7 27 09 - 9D 33 58 38 4D AB 16 C8
Nov  6 16:45:47.706: %AUTHMGR-5-START: Starting 'dot1x' for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
Nov  6 16:47:19.971: %DOT1X-5-FAIL: Authentication failed for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
Nov  6 16:47:19.971: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
Nov  6 16:47:19.971: %AUTHMGR-7-FAILOVER: Failing over from 'dot1x' for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
Nov  6 16:47:19.971: %AUTHMGR-7-NOMOREMETHODS: Exhausted all authentication methods for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
Nov  6 16:47:19.971: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
The configuration is as follows:
hostname xxx
boot-start-marker
boot-end-marker
enable secret 4 eaOP83n/Avy2EAs2tg7JbhLCX5T8h39E3GwBeTDW5sY
username xxxprivilege 15 password 0 xxx
aaa new-model
aaa group server radius IAS
 server 10.95.1.114 auth-port 1812 acct-port 1813
aaa authentication login userAuthentication local group IAS
aaa authentication dot1x default group radius
aaa authorization exec userAuthorization local group IAS if-authenticated
aaa authorization network userAuthorization local group IAS
aaa accounting exec default start-stop group IAS
aaa accounting system default start-stop group IAS
aaa session-id common
switch 1 provision ws-c2960x-24ps-l
no ip domain-lookup
ip domain-name xxx
dot1x system-auth-control
spanning-tree mode pvst
spanning-tree vlan 1,100 priority 61440
vlan internal allocation policy ascending
interface GigabitEthernet1/0/23
 switchport mode access
 authentication port-control auto
 dot1x pae authenticator
 spanning-tree portfast
interface GigabitEthernet1/0/24
 switchport mode trunk
interface Vlan1
 ip address dhcp
interface Vlan100
 ip address 10.100.52.10 255.255.0.0
ip default-gateway 10.100.52.12
ip http server
ip http secure-server
ip radius source-interface Vlan100
radius-server host 10.95.1.114 key xxxxx
radius-server host 10.95.1.114 auth-port 1812 acct-port 1813 key xxxxx
line con 0
 logging synchronous
line vty 0 2
 exec-timeout 0 0
 logging synchronous
 login authentication userAuthentication
 transport input telnet ssh
line vty 3 4
 exec-timeout 0 0
 logging synchronous
line vty 5 15
 exec-timeout 0 0
 logging synchronous
end
I hope you can help me
Best regards
nspasov
The log message
\Nov  6 16:47:19.971: %AUTHMGR-7-RESULT: Authentication result 'no-response' from 'dot1x' for client (3c97.0edd.75c9) on Interface Gi1/0/23 AuditSessionID 0A64340A00000082046F3A65
means that the client is not responding to the EAPoL based massaged. The NAD (in your situation a switch) is sending the "Access-Request" message to the endpoint but the endpoint is not responding. This would indicate that the endpoint supplicant is not properly configured to perform dot1x. With that being said can you tell us:
1. What type of endpoint is this? Windows, MAC, etc
2. What type of dot1x authentication are you trying to perform? PEAP, EAP-TLS, etc?
The next log message:
is indicating that since the dot1x authentication failed, the NAD will try the next available and configured authentication method (MAB, web auth, etc)
However, the following log message
Informs you that all configured authentication methods had been tried. This is because you only have dot1x configured as an authentication method. If you want you can configure MAB, webauth, etc
This final log message:
Simply states that the dot1x process failed so your client will be getting an "Access_Reject" and will not be allowed on the network
I hope this helps!
Thank you for rating helpful posts!
