%DOT1X-5-FAIL: Authentication failed
Jason2005
Trying to authenticate I have this error as shown, can anyone help me!
*May 11 12:38:20.482: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.3:1812,18 13 is not responding.
*May 11 12:38:20.482: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.3:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:38:22.545: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.4:1812,18 13 is not responding.
*May 11 12:38:22.545: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.4:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:38:28.631: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.4:1812,18 13 is not responding.
*May 11 12:38:28.636: %MAB-5-FAIL: Authentication failed for client (5000.000c.0 000) on Interface Et1/0 AuditSessionID C0A864FE0000000C0000E642
SwitchL3#
*May 11 12:38:28.649: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.4:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:40:42.759: %DOT1X-5-FAIL: Authentication failed for client (5000.000c .0000) on Interface Et1/0 AuditSessionID C0A864FE0000000C0000E642
SwitchL3#
*May 11 12:40:55.204: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.3:1812,18 13 is not responding.
*May 11 12:40:55.204: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.3:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:41:03.360: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.4:1812,18 13 is not responding.
*May 11 12:41:03.360: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.4:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:41:05.386: %DOT1X-5-FAIL: Authentication failed for client (5000.000c .0000) on Interface Et1/0 AuditSessionID C0A864FE0000000C0000E642
SwitchL3#
*May 11 12:41:36.277: %DOT1X-5-FAIL: Authentication failed for client (5000.000c .0000) on Interface Et1/0 AuditSessionID C0A864FE0000000C0000E642
SwitchL3#
*May 11 12:41:40.318: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.3:1812,18 13 is not responding.
*May 11 12:41:40.318: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.3:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:41:48.417: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.4:1812,18 13 is not responding.
*May 11 12:41:48.417: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.4:1812,1 813 is being marked alive.
SwitchL3#
*May 11 12:41:52.508: %MAB-5-FAIL: Authentication failed for client (5000.000c.0 000) on Interface Et1/0 AuditSessionID C0A864FE0000000C0000E642
SwitchL3#
Mark Elsen
  - Looks like the radius server is not really reachable from the switch ; you may try to ping it (e.g.)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Jason2005
@Mark Elsen
now after i set everything right and the authentification is good (dot1x), my windows server could not reach his gateway in order to give hosts a DHCP IP addresses!
help please! @Mark Elsen
 - Sorry with that kind of soon messaging (replies)  , unrelated follow-up's (e.g.) ; you loose your credibility and it points to lack of structured messaging and or clear  formulation of problems ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
