Dot1x authentification failed (Cisco IOL L3 - Cisco ISE (RADIUS))
Jason2005
So basically I have this problem I have setted policies for Dot1x and MAB on both Cisco IOL L3 (version 15) and Cisco ISE (RADIUS Server) but client do authentificate only with the default method which is MAB (I did set an order for methods on Switch, see full Switch IOL Configuration in images below).
Can anyone guide me!
@dot1x
Troubleshoot Dot1x and Radius in IOS and IOS-XE
authentification host-mode multi-auth
catalyst switch での AAA / Dot1X / MAB に関連する問題が発生した際に取得するログ
Troubleshoot Wired Dot1x Issues in ISE 3.2 and Windows
7 Replies 7
If you run
Debug dot1x
Debug radius
And you dont get anything
Then it issue of CML not issue of config
To be honest I never see one success use dot1x in CML eve-ng or gns3
MHM
Jason2005
 Debug radius command is giving me the below output!
@MHM Cisco World
This meaning that radius debug is ON
When you try access via endpoint do you see any debug ?
MHM
Jason2005
now switch is showing me the below outputs :
@MHM Cisco World
That good ghe dot1x magically work.
What issue you see'
Do
Show authentication interface session
Check the status of endpoint authc and authz
MHM
Jason2005
yeah everything working fine now
but I'm running into another DHCP problem, server could not reach its Gateway and could not give IPs to hosts!
Can I see
Show authentication session of this interface
MHM
