dot1x feature
acbenny
Dear expert,
I am testing the the dot1x feature and get the below result. I feel point 4 is not quite make sense.
Can I make that for dot1x client, Even they haven't enter their username and password, they also will
not be assigned to guest vlan ( vlan 99)
interface FastEthernet0/24
switchport mode access
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
dot1x guest-vlan 99
dot1x auth-fail vlan 999
spanning-tree portfast
1) wait 30 sec for username prompt
2) For three times password verify fail, port 24 will cange to vlan 999
3) For dot1x non compatible client, wait 1 min 30 sec, port will change to vlan 99
4) For dot1x client, If connect to port 24 but not login, wait 1 min 30 sec, port will change to vlan 99
b.julin
Level 3
Level 3
You mean you want machines treated differently just because they are running a dot1x client? That does not seem very useful behavior. Anything can start a dot1x client.
Perhaps you want to look at machine level authentication so that the machine authenticates itself automatically, and then when a user logs in it reauthenticates as a user. Then you can send a different vlan depending on whether the machine is being used or not.
Or mac auth bypass.
