hello,
we want to use dot1x guest-vlan with PXE. now we ran into the problem that with default-timers PXE doesn´t work (very probably the client doesn´t have an IP when PXE is started).
to speed up the guest-vlan we will decrease tx-period to seconds.
but we also want to decrease the number of attempts to authenticate the device. and here i saw two commands where i don´t understand the difference:
dot1x max-start
dot1x max-reauth-req
what is the difference between these two commands and which one would fit better in guest-vlan scenario.
br + thx
