Dot1x with Multi-Domain vs Multi-Auth
CSCO11854658
We had configured dot1x on ports of Switch ports with authentication host-mode multi-domain and ports were going to err-disabled mode.
This was rectified once we configured port to authentication host-mode multi-auth.
PC are connected through IP phones and below is switchport configuration. IP phones are profiled correctly in ISE.
switchport access vlan 200
 switchport mode access
 switchport voice vlan 1100
 ip access-group ACL-ALLOW in
 authentication event fail action next-method
 authentication open
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
 spanning-tree bpdufilter enable
 spanning-tree bpduguard enable
We would like to know why is it going to error disabled mode and how can we rectify  issue caused by using multi-domain.
This was working fine for more than three months with multi-domain and faced this issue on next day of ISE 1.4  patch update (Patch-3).
Switch details:
·         WS-C3750X-48P
·         IOS-C3750E-UNIVERSALK9-M
·         Version 15.0(2)SE7
0 Replies 0
