double discover DHCP message sent by distribution switch
devmohamedh219
in this topology, configured HSRP + Ip helper-address to DHCP server in distribution switch.
1- when VPC10 send broadcast DHCP discover will go from access switch1 e1/2 and e1/0 to distribution switch 1 and 2.
2- distribution switch 1,2 will send discover message to DHCP Server
192.168.103.1 => distribution1
192.168.103.2 => distribution2
Should we take care of this problem?
Hi @devmohamedh219
 This is not a problem actually and the DHCP will reply to the first query
HI
it does not stable with HSRP, you can see this is good solution.
