Downgrade IOS from 15.0(2)SE6 to 12.2(55)SE7 issues
jschroeder0816
I received 2x 2960PCL switches that were shipped with IOS 15.0(2)SE6. I have attempted to downgrade these switches to 12.2(55)SE7 without success. So far I have pushed the 12.2 image to the switch via xmodem. When trying to boot from the image the switch installs and executes the image then spits out the following:
File "flash:c2960-lanbasek9-mz.122-55.SE9.bin" uncompressed and installed, entry point: 0x3000
executing...
 : Unexpected exception to CPUvector 1100, PC = 6280A8
-Traceback= 6280A8 65813C 14CBA08 152D28C 352C
 : Unexpected exception to CPUvector 0, PC = 6280A8
-Traceback= 6280A8 15344F0 A30748
Nested write_crashinfo call (2 times)
It then loops:
I have formatted the flash and repeated the process with the same results. Any help would be appreciated.
6 Replies 6
Tagir Temirgaliyev
please copy paste here
sh ver
sh inv
Switch#show ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.0(2)SE6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 09-Apr-14 03:40 by prod_rel_team
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 15.0(2r)EZ1, RELEASE SOFTWARE (fc2)
Switch uptime is 1 minute
System image file is "flash:/c2960-lanbasek9-mz.150-2.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960+24PC-L (PowerPC405) processor (revision B0) with 131072K bytes of memory.
Processor board ID FCW1816B1WV
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 28:C7:CE:E2:9B:80
Motherboard assembly number     : 73-15618-01
Power supply part number        : 341-0266-03
Motherboard serial number       : FOC18159K1Z
Power supply serial number      : DCA1813H04W
Model revision number           : B0
Motherboard revision number     : B0
Model number                    : WS-C2960+24PC-L
System serial number            : FCW1816B1WV
Top Assembly Part Number        : 800-40259-01
Top Assembly Revision Number    : C0
Version ID                      : V01
CLEI Code Number                : CMMKU00ARA
Hardware Board Revision Number  : 0x03
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960+24PC-L    15.0(2)SE6            C2960-LANBASEK9-M
Configuration register is 0xF
Switch#sh inv
NAME: "1", DESCR: "WS-C2960+24PC-L"
PID: WS-C2960+24PC-L   , VID: V01  , SN: FCW1816B1WV
did you verifyed image file? before reload it?
verif     flash:c2960-lanbasek9-mz.122-55.SE9.bin
it will calculate checksumm
and dont forget to rate post
Ok, a few things with this.
Switch#dir flash:
Directory of flash:/
    2  -rwx        1919   Mar 1 1993 00:01:08 +00:00  private-config.text
    3  -rwx    11792256   Jan 1 1970 00:58:51 +00:00  c2960-lanbasek9-mz.150-2.SE6.bin
    4  -rwx        3096   Mar 1 1993 00:01:08 +00:00  multiple-fs
    6  -rwx     9821824   Jan 1 1970 00:01:58 +00:00  c2960-lanbasek9-mz.122-55.SE9.bin
    7  -rwx        1561   Mar 1 1993 00:01:08 +00:00  config.text
Switch#verify flash:c2960-lanbasek9-mz.122-55.SE9.bin
And
Switch#verify flash:/c2960-lanbasek9-mz.122-55.SE9.bin
Returns:
File system hash verification failed for file flash:c2960-lanbasek9-mz.122-55.SE9.bin(No such file or directory).
Switch#verify /md5 flash:c2960-lanbasek9-mz.122-55.SE9.bin
Returns:
...........Done!
verify /md5 (flash:c2960-lanbasek9-mz.122-55.SE9.bin) = a426418bb0957afd3184612592b253df
fciv shows the original file value to be different:
C:\Program Files (x86)\teraterm>fciv c2960-lanbasek9-mz.122-55.SE9
// File Checksum Integrity Verifier version 2.05.
e668bede8824f56c576f007e1ed85f31 c2960-lanbasek9-mz.122-55.se9.bin
Also:
The md5 checksum changed for another image after it was uploaded to the switch: c2960-lanbasek9-mz.150-2.SE6.bin
However, there are no issues booting from this image.
Switch#verify /md5 c2960-lanbasek9-mz.150-2.SE6.bin
....Done!
verify /md5 (flash:c2960-lanbasek9-mz.150-2.SE6.bin) = 3771cdaaccee60e5d8163ca593d825d1
C:\Program Files (x86)\teraterm>fciv c2960-lanbasek9-mz.150-2.SE6.bin -md5
7590376c9a1c17fcbd019b48d8f4c2c9 c2960-lanbasek9-mz.150-2.se6.bin
Thanks for your replies!
both ios files in your flash are not good. corrupted. copy again and verify.
Returns:
...........Done!
http://software.cisco.com/download/release.html?mdfid=280836706&softwareid=280805680&release=12.2.55-SE9
Description: LAN BASE
Release: 12.2.55-SE9
Release Date: 18/Mar/2014
File Name: c2960-lanbasek9-mz.122-55.SE9.bin
Min Memory: DRAM 64 MB Flash 32 MB
Size: 9.37 MB (9821732 bytes)
MD5 Checksum: e668bede8824f56c576f007e1ed85f31
Release Notes for 12.2(55)SE9 | Field Notices
and dont forget to rate posts
BRIAN ARTHUR
I am getting similar results with a WS-C2960-48PST-L. The switch was previously was running 15.0 and I wanted to downgrade to 12.2. I loaded the new 12.2 software and got the looping "Unexpected exception to CPUvector 1100". I have run "format flash:" and the boot process hangs after this message, "...uncompressed and installed, entry point: 0x3000 executing…". It was hung for at least 10 minutes, I didn't try letting it go longer.
I also tried "archive download-sw /force-ucode-reload" when attempting to downgrade to 12.2 and I am sure that my images were not corrupt. IE. the "verify /md5" command checked out OK.
I am now installing 15.0 via XMODEM, a slow process...
