Downloading Firmware
Iloveyou
Is it possible to download ROMMON firmware from a cisco switch or router?
ROMMON not ios.
6 Replies 6
Blue_Bird
Yes...you can do it....
Please go through the link...which gives the detailed procedure...
https://www.cisco.com/c/en/us/td/docs/routers/access/hardware/notes/dwnld_rom.html
Best regards
******* If This Helps, Please Rate *******
Incorrect. I want to download FROM switch TO thumb drive or computer. I need the ROMMON
ok...got it...
M02@rt37
Hello @Iloveyou,
Yes! Which platform have you got?
Best regards
Isr 4321
Joseph W. Doherty
From "installed"?  I believe not.
