Dual default ospf routes
m.egan
Hi - I'm working on a design with two different ISP providers. I'm running BGP with the providers and advertising my company owned address block. AS-prepending on one side. That's working fine.
I'm running OSPF in the inside with a Check Point firewall cluster. The two ISP routers are only sending the default route to the firewalls.
Router-A
router ospf 1
default-information originate
Router-B
router ospf 1
default-information originate metric 155
Both Routers and the Firewalls are all on the same segment. I can see neighbor relationships, LSA database etc.
I'm expecting that when Router-A (primary) goes down, the route to Router-B comes in. That seems to be working fine. Now when Router-A comes back I'm expecting the firewall to start using the route to Router-A again but its not. Am I miss-interpreting this behavior?
This seems like such a basic design/config - I baffled as to why its not working. Do I need to adjust or tweak DR/BDR or anything of that nature.
PS - I have a TAC case open with Check Point but I just wanted to sanity check this with the group here.
Thanks in advance for the help.
Giuseppe Larosa
Hello Matthew,
the router should generate again an OSPF default route after restore IF a default route, not coming from OSPF domain, is present in the IP routing table.
So you need to check the IP routing table of Router-A after the restore to see if:
a default route is present in the IP routing table
that default route is NOT the OSPF route generated by Router-B
Check the OSPF database on Router-A after restore to see if the locally originated LSA for 0.0.0.0 is present.
if the OSPF LSA is present Router-A should flood it and the firewall should use it again.
Hope to help
Giuseppe
