Duplex mismatch between N7k and 5508
Hi All,
I met a duplex mismatch issue in our new DC.
The port configuration on the N7k and controller is the same as in other DC
Only difference is version of the NxOS on the N7k.
On N7k 5.2(1) works
On N7k 5.2(7) i get below logs :
2013 Aug 21 22:23:24 xxx %CDP-4-DUPLEX_MISMATCH: Duplex mismatch discovered on Ethernet10/8, with LAGInterface0/3/1
2013 Aug 21 22:24:24 xxx last message repeated 8 times
2013 Aug 21 22:25:24 xxx last message repeated 8 times
2013 Aug 21 22:27:24 xxx last message repeated 16 times
2013 Aug 21 22:29:24 xxx last message repeated 16 times
Port configuration :
interface Ethernet10/8
  description WLC 5508-1
  switchport
  switchport mode trunk
  switchport trunk native vlan 50
  switchport trunk allowed vlan 50,500,570
  spanning-tree port type edge trunk
  channel-group 1100
  no shutdown
xxx# sh int e 10/8
Ethernet10/8 is up
Dedicated Interface
  Belongs to Po1100
  Hardware: 10/100/1000 Ethernet, address: 0006.f6b1.d2f7 (bia 0006.f6b1.d2f7)
  Description:WLC 5508-1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 1000 Mb/s
Controller 5508 version 7.3.112.0
Controller ports :
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE    SFPType
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
2  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
3  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
4  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A     1000BaseTX
How can i fix this issue ? Ports are set up and show the same - 1000 / Full
the messages are annoying as loggs are almost full of them.
Thank you in advance
myoder789
Radoslaw,
Did you ever receive an answer to your question? If you know how to fix this issue, can you let me know? We are experiencing the same issue in our environment.
Matt Yoder
Hi Matthew,
The issue is related to bug -> "CDP duplex mismatch when using LAG on 5508 & 8510 WLC” (CSCuc94082)
The fastest way to solve (workaround) this is disable cdp on the controller by executing following command:  config cdp advertise-v2 disable
Hope this helped you
Radek
I have the same issue between N7K and AIR-WLC4404-100-K9. I will try to disable CDP advertise on WLC.
You can then use LLDP as a workaround to loosing CDP feature sue to the bug , it may only effect CDP feature
