DWDM-XFP-C
Wii1221173
Hi everyone,
I'm trying to make my DWDM-XFP-C to work in my CRS-1 at wavelength 55 but the port keeps reporting a wrong wavelength when I do the show controller command:
RP/0/RP0/CPU0:Lab1#show controller dwdm0/2/0/1 optics
Mon Aug  4 17:22:04.659 UTC
Optics Status
         Optics Type:  10G-TUNABLE-by-CHANNEL,
         Wavelength Info: C-Band, MSA ITU Channel=84, Frequency=191.95THz, Wavelength=1561.826nm
         Wavelength Owner: Hardware Default, ITU Channel: GMPLS Signaled=None, Configured=55, Hardware Default=None
         TX Power = 1.50 dBm
         RX Power = -40.00 dBm
         Chromatic Dispersion = -1 ps/nm
         Differential Group Delay = -0.01 ps
         Second Order Polarization Mode Dispersion = -1 ps^2
         Optical Signal to Noise Ratio = -0.01 dB
         Polarization dependent Loss = -0.01 dB
         Polarization Change Rate = -1 rad/s
         Phase Noise = 4294967.295
any suggestion would be appreciated
Thank you
0 Replies 0
