Dynamic Addressing with DHCP Quiz
JA80675
Just completed the quiz as part of the Networking Basics Course for Cisco Junior CyberSecurity Analyst pathway but confused at Q3. The question is Which message does an IPv4 host use to reply when it receives a DHCPOFFER message from a DHCP server? Your options are: DHCPACK, DHCPDISCOVER, DHCPOFFER & DHCPREQUEST.
Originally I went with my answer which is DHCPREQUEST but got it wrong according to the quiz itself which opted for DHCPOFFER.
I searched the exact question and pasted into google which had the same answer of DHCPREQUEST and which is correct matching my answer like for like.
Can someone please explain why the quiz did not acknowledge the correct answer and chose the wrong answer instead?
Jabed
Also quizzes are somtimes wrong. And this is a hard truth you also have to learn for your first real exam that you take.
Ruben Cocheno
@JA80675
It's hard to tell you, and sometimes some nuances changes the all context of the question.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
