Dynamic IP issue on the client
son ray
I have setup a LAb for the DHCP relay. DHCP are created on the router and intervlan routing is there.
vlan 10 and vlan 20 has been configured on multilayer switch and l2 switch locally. PC0 is in vlan 10 and PC1 is in vlan 20. ip helper command given on the vlans on a multilayer switch.
i,m attaching topology looking for someone help.
Jitendra Kumar
your router config looking good..
please check the below points
Multilayer switch Port-F0/2, F0/1 should be trunk
multilayer should have a default route as well to forward traffic to the router
IP route 0.0.0.0 0.0.0.0 10.0.0.1
L2 Switch Port- F0/1 should be trunk
you are saying you have done intervlan and VLANs and other configs .
Jitendra
Jitendra
7 Replies 7
Jon Marshall
Post configuration of router and switch.
Jon
Router>en
Router#sh run
Building configuration...
Current configuration : 1004 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool vlan10
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 8.8.8.8
domain-name wr
ip dhcp pool vlan20
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017K504-
spanning-tree mode pvst
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 10.0.1.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.0.2.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
That is just the router but you talk about SVIs and ip helper addresses on the switch.
If the router is meant to be routing between vlans then you don't need the SVIs on the switch, just configure the link from the switch to th router as a trunk.
Jon
Make sure the uplinks between switches and switch and router  are in trunk. And attach the PacketTracer here zipped that´s make it easier to help you.
Jitendra Kumar
Jitendra
Jitendra
checking..
I was missed l2 uplink as trunk...
thanks, team for the support
