edge command in the switch
Mary
In the access switch, under G1/0/5, I define two vlan, one for data, one for voice (ip phone), access port, should I use spanning-tree portfast edge or spanning-tree portfast, which one is better?
You should also set as best practice spanning-tree bpduguard enable under access ports with portfast
