EEM help with ethernet port shut down ...
Mark Hazell
Would anyone know if EEM can be configured to shut down an ethernet port at a certain time of day and then to un shut the port again at a certain time?
Energywise is unfortunatley not an option.
Many thanks
Hi Mark,
Two applets , one shut , one no shut, both using cron timer.Shutdown ad 23:59 and un-shut at 08:59
event manager applet SHUT
event timer cron cron-entry "59 23 * * *"
action 1 cli command "en"
action 2 cli command "conf t"
action 3 cli command "int fa0/0"
action 4 cli command "shut"
event manager applet NO-SHUT
event timer cron cron-entry "59 08 * * *"
action 4 cli command "no shut"
Dan
Hi Dan,
Many thanks it worked first time, cheers for the help.
