EEM script not working on cisco 3750
Asim Afzal
HI,
i have applied below script and i can see the script successfuly exceuted but i cant see the file which should store on the flash.Below is script
event snmp oid 1.3.6.1.4.1.9.2.1.56 get-type next entry-op ge entry-val 60 exit-time 10 poll-interval 1
action 1.1 syslog msg "CPU Utilization is high"
action 1.2 cli command "en"
action 1.3 cli command "show proc cpu sorted | append flash:abc.txt"
action 1.4 cli command "show proc cpu history | append flash:cpu2info.txt"
action 1.5 cli command "show ip inter bri | append flash:cpu3info.txt"
action 1.5 syslog msg "cpu commands verification"
wheni  do show flash i cnat see the files in the flash.
Renan Abreu
Hi Asim,
     Your script is configured to start collecting when CPU reaches 60% did it reach this value since you applied it?
     Can you change it to a lower value such as 5% and check if it works?
What are you trying to achieve there?
You can use the script I use if you want to.
service internal
event manager applet high_cpu
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.6.1 get-type exact entry-op ge entry-val "85" poll-interval 5 ratelimit 60
action 1.0 syslog msg "CPU Utilization is above 85%"
action 2.0 cli command "enable"
action 2.1 cli command "clear mls qos | append flash:eem_alta_de_CPU.log"
action 2.2 cli command "show clock | append flash:eem_alta_de_CPU.log"
action 2.3 cli command "show proc cpu sor | exc 0.0  | append flash:eem_alta_de_CPU.log"
action 2.4 cli command "show proc cpu his | append flash:eem_alta_de_CPU.log"
action 2.5 cli command "show mls qos ip | append flash:eem_alta_de_CPU.log"
action 2.6 cli command "show policy-map control-plane all | append flash:eem_alta_de_CPU.log"
action 2.7 cli command "show mls qos | append flash:eem_alta_de_CPU.log"
action 2.8 cli command "show mls qos statistics-export info | append flash:eem_alta_de_CPU.log"
action 2.9 cli command "show mls qos protocol | append flash:eem_alta_de_CPU.log"
action 3.0 cli command "show interfaces | append flash:eem_alta_de_CPU.log"
action 3.1 cli command "show interfaces switching | append flash:eem_alta_de_CPU.log"
action 3.2 cli command "show interfaces stat | append flash:eem_alta_de_CPU.log"
action 3.3 cli command "show ip nat transl | append flash:eem_alta_de_CPU.log"
action 4.0 cli command "show align | append flash:eem_alta_de_CPU.log"
action 4.1 cli command "show ver | append flash:eem_alta_de_CPU.log"
action 4.2 cli command "show log | append flash:eem_alta_de_CPU.log"
action 4.3 cli command "show stacks | append flash:eem_alta_de_CPU.log"
action 5.0 cli command "show ip cef summary | append flash:eem_alta_de_CPU.log"
action 5.1 cli command "show cef interface | append flash:eem_alta_de_CPU.log"
action 6.0 cli command "show ip interface | append flash:eem_alta_de_CPU.log"
action 7.0 cli command "show cef not-cef-switched | append flash:eem_alta_de_CPU.log"
action 7.1 cli command "show cef drop | append flash:eem_alta_de_CPU.log"
action 8.0 cli command "show ip cache flow | append flash:eem_alta_de_CPU.log"
action 9.0 cli command "show pxf accounting summary | append flash:eem_alta_de_CPU.log"
action 9.1 cli command "show region | append flash:eem_alta_de_CPU.log"
action 9.2 cli command "show memory statistics | append flash:eem_alta_de_CPU.log"
action 9.3 cli command "show ip traffic | append flash:eem_alta_de_CPU.log"
I have the same issue:
event manager scheduler script thread class default number 1
event manager applet High_CPU
event snmp oid
1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge entry-val 50 poll-interval 0.5
  action 0.0 syslog msg "High CPU DETECTED. Please wait - logging Information to file flash:high_cpu.txt"
  action 0.1 cli command "enable"
  action 0.2 cli command "show clock | append file flash:high_cpu.txt"
  action 1.2 cli command "term length 0"
  action 1.3 cli command "show process cpu sorted | append file flash:high_cpu.txt"
  action 1.4 cli command "show log | append file flash:high_cpu.txt"
  action 1.5 cli command "term length 24"
What happens is the threshold is exceeded and a message is sent to syslog but the file is never created as if the rest of the commands never processed.
Sep 18 11:38:43.457: %HA_EM-6-LOG: High_CPU: High CPU DETECTED. Please wait - logging Information to flash:high_cpu.txt
mcrh12-es-03#dir
Directory of flash:/
    2  -rwx         616  Feb 28 1993 19:01:57 -05:00  vlan.dat
    3  -rwx        3566  Sep 17 2013 15:30:57 -05:00  private-config.text
    4  -rwx        2072  Sep 17 2013 15:30:57 -05:00  multiple-fs
    5  -rwx       44456  Sep 17 2013 15:30:57 -05:00  config.text
    6  drwx         512  Feb 28 1993 19:12:45 -05:00  c3750e-universalk9-mz.150-2.SE
57671680 bytes total (32539136 bytes free)
