Eigrp and static route
what would be the reason you would use static routes advertise with eigrp networks on a router?
Richard Burts
Let me suggest an example where there are 3 routers. RouterA connects to RouterB which connects to RouterC. RouterB andRouterC run EIGRP between them. There is not a dynamic routing protocol running between RouterA and RouterB (perhaps RouterA belongs to one company and RouterB and RouterC belong to a different company so you do not want a routing protocol running between the companies). Let us assume that network 2.2.2.0 is connected on RouterA and that RouterB and RouterC need to access network 2.2.2.0. How would you do that? The easy solution is to configure a static route on RouterB so that RouterB now has access. Then you redistribute the static route into EIGRP so that it is advertised to RouterC and now both RouterB and RouterC have access to network 2.2.2.0.
Rick
Rick
Do you redistribute the static route into eigrp for traffic entering router b from router c or traffic going from router b to router c or is for traffic going in both direction on router b?
I do not understand your question very well. In my example RouterB knows about 2.2.2.0 because of the static route. We redistribute the static route so that RouterC can learn about 2.2.2.0. So perhaps the answer to your question is traffic entering router b from router c.
Rick
Rick
