05-12-2017 11:28 AM - edited 03-08-2019 10:33 AM
I have a doubt related to EIGRP metric calculation by router.
Suppose following is my topology
If i am correct,
R2 receives two advertisement for y.y.y.y with path through R5 as successor.
R2 will calculate the metric to network y.y.y.y with 256k (R5-R4) as min bandwidth along the path.
Now my question is
? How R2 came to know the R5-R4 link has min bandwidth along the path.
Did R5 share the bandwidth info or did R2 calculated it from R5's AD.
Please clarify my doubt.
Further doubts my follow.
Santosh
Solved! Go to Solution.
05-12-2017 11:44 AM
Santosh
The advertisement from R5 will have a field with the minimum bandwidth for the path to y.y.y.y. Then R2 will compare the advertised minimum bandwidth to the local bandwidth and calculate the metric using the lower of the two values.
Rick
05-12-2017 11:44 AM
Santosh
Rick
05-12-2017 12:09 PM
Thanks Richard,
That was really helpful.
05-12-2017 01:10 PM
Santosh
You are welcome. I am glad that my response was helpful.
Rick
