EIGRP neighbor router-id issue
mh.gorjizadeh
Hello guys
I have a question , it may be simple but  honestly i couldn't find any answer for it.
How can i find eigrp neighbor Router-id ?
InayathUlla Sharieff
Dear,
There is nothing such as EIGRP neighbor Router-id. But were in you have the EIGRP Router-id command.
The EIGRP router ID is chosen as the highest IP address on an active interface on the router, unless loopback interfaces are configured, in which case it is the highest IP address assigned to a loopback interface. Alternatively, if the eigrp router-id ip-address router configuration command.
router-1(config)#router eigrp 7
router-1(config-router)#eigrp router-id 3.3.3.3
Here are teh details what EIGRP router id do:-
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/18685-eigrp-dup-id.html
Inayath
**Please do nt forget to rate if this info is helpfull.
Dear,
Inayath
