eigrp routing
carl_townshend
hi all
i have a remote site with a primary e1 and backup dsl router, same at the head office, if i try to run a ping to the primary router through the isp core it goes one way, if i try to ping the backup dsl router it goes another way, how come the ping to the backup does not go through the primary at the remote end?
kwillacey
Level 3
Level 3
you might want to check the routing tables, post them if you can and indicate the destination networks.
