Embedded packet capture - BGP problem
mediaworksnz
Level 2
Level 2
Hello, I am unable to capture BGP traffic on my Cisco 1921 router (Version 15.4(2)T1) via the tcpdump IOS commands. All other traffic I can capture successfully.
Is this because BGP traffic is on a plane outside the reach of Embedded Packet Capture ?
You should see some BGP packets, but there are some restrictions according to the following document:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/epc/configuration/15-mt/epc-15-mt-book/nm-packet-capture.html#GUID-CF6AFCF6-34DC-4B16-9406-E73C806FBD2E
Restrictions for Embedded Packet Capture
  • EPC only captures multicast packets on ingress and does not capture the replicated packets on egress.
Reza Sharifi
Not sure about that but you can also use a debug command to see bgp traffic.
debug ip bgp...
be careful if this is in production not to overwhelm the router.
