Enable Netflow on Catalyst 4500
louisweng
Hi All,
I have a Catalyst 4500 L3(WS-C4507R) switch running on version 12.2(53)SG with Netflow services card WS-F4531 installed. I need it to send netflow traffic details to my WhatsUp's flowmonitor.
With reference to Whatsup's flow monitor guide
http://docs.ipswitch.com/NM/79_WhatsUp%20Gold%20v15/03_Help/index.htm?30317.htm?toc.htm
I have set the following on my switch
ip flow ingress infer-fields
ip flow-export source Looopback0
ip flow-export version 5
ip flow-export destination <whatsup server's ip address) 9999
ip route-cache flow infer-fields
1) I found that my WhatsUp's flow monitor is able to detect incoming traffic on the switch but not outgoing traffic details. Is there command to enable egress on my switch?
2) Seems that i am not able to set "ip flow ingress" and "ip flow egress" on interface level. Is there anyways it can be done rather than switch level?
Louis
0 Replies 0
