Enable password is not working via SSH
jdurgam
I have configured Enable password but am not getting into prompt directly getting into enable mode for the same am attaching the images for reference.
Config
HYD-TBAL-P1STORES-SW1#sh running-config | include enable
enable secret 9 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps cpu threshold
login as: jdurgam
Pre-authentication banner message from server:
End of banner message from server
Keyboard-interactive authentication prompts from server:
| Password:
End of keyboard-interactive prompts from server
There have been 4 successful attempts in the past 1 hours
Hello
apply the following and test again, remove anything else on the vty lines other then what is below
sw
conf t
username TEST password  test123
enable secret secret123
line vty 0 4
login local
transport input telnet ssh
Kind Regards
Paul
15 Replies 15
Hello
the enable secret will over ride the enable password - the two are mutually exclusive to each other
Kind Regards
Paul
HI Paul,
I have removed the enable password i kept only enable secret but still not working.
Can I see all SW config
MHM
Hi MHM
find below configuration.
Helllo
whars not working -ssh or the enable secret  or both  -are you using local user access or just exec password login
enable secret xxx
line vty 0 4
transport input ssh telnet
password xxxx
or
login local
Kind Regards
Paul
HI
Am using SSH to logon and am using local user access only.
And  tried that you mentioned commands on above comment still it is not working.
Hello
So what is not working?
  • SSH
  • local access to exec mode
  • privileged exec mode (enable)
Edited: just noticed HYD-TBAL-P1STORES-SW1#
which means you have access into privileged exec mode so I dont understand what isn working, can you elaborate?
Kind Regards
Paul
HI,
yes am able to enter into the privileged exec mode without password prompt.
Am able to access switch using SSH but am going directly in to the Global configuration mode after giving local user credentials.
but need privilege mode password prompt to access it.
Friends if you use local username and specify privilege 15 then when access you can directly to level 15
You need to add new user without level
Then try access via ssh/telnet
MHM
hi MHM
I have created new user without privilege but am unable login find attached config file.
That not all config
and I see you try 4 failed attempts
Then check
Show login
Maybe you enter to quite mode in which ypu need to wait specfic time before try again
MHM
Hi MHM
I TRIED AFTER SOME TIME STILL AM UNABLE LOGON
 did you use same username ?
Try access via telnet not ssh and check if you can access
MHM
Hello
sw
conf t
line vty 0 4
login local
Kind Regards
Paul
