Enabling DHCP snooping
Andy White
Level 3
Level 3
We have a 2960 48 port switch in a remote office with a couple of VLANs (VOIP & Data).  The L3 routing is provided via the WAN router and acts as a 'router on a stick' and provides DHCP for both VLANs.
I need to enable DHCP snooping and I have issued the 'ip dhcp snooping trust' on the router port but not for the access ports.  I have then added 'ip dhcp snooping' to the switch but not 'ip dhcp snooping vlan x , x' as I was hoping the ip dhcp snooping bindings database would start to fill up after a few days but it hasn't.
If I add 'ip dhcp snooping vlan x , x' I think the users will get issues as there is no database, what should I do as the router is doing the DHCP.
petenixon
Level 3
Level 3
You need to identify the vlans where snooping should be implemented using:
ip dhcp snooping vlan #
The default allows dhcp requests on untrusted ports.
That's my question, if I enable it on the vlans and the database isn't populating, what will happen?
DHCP snooping keeps track of the bindings but you first have to identify what vlans need tracking.
Thanks, but what will happen if I enable this and the database isn't populated yet?
