Enabling Http on a 3560 switch
omgjames1
I have a couple of 3560 switches and I had Http enabled (LAN), now for some reason i cannot get to them from inside the network using the internal IP address. Can someone give me the command to do that?
James,
Please post the configuration regarding your question. Let's check things as follows:
1."no ip http access-class xxx"
#you can modify it based on your security policies.
2."ip http server"
3."ip http authentication local"
4."username optimusprime privi 15 password megatron"
HTH,
Toshi
and you're able to ping the IP address of the switch?
