Enabling NBAR on switches???
blarkins1
How do you enable NBAR on 3750 or 3560 switches?  ...or is this even possible?
I need to see what type of traffic is going across my LAN and what is using up all the bandwidth.
Thanks!
2 Accepted Solutions
   C3750 and C3560 don't support NBAR. You can check the features on datasheets or feature navigator on link below.
   Ref: http://www.cisco.com/web/go/fn
HTH,
Toshi
esomarriba
Level 5
Level 5
Hi blarkins1,
We don't have support for NBAR on 3560 platform.
HTH,
Elyinn.-
HTH,
Toshi
esomarriba
Level 5
Level 5
Hi blarkins1,
HTH,
Elyinn.-
