Enabling routing Cisco 4507 switch
We have a 4507 and going through the steps to enable routing, doesn't seem to make any change in the switch. Am I missing something here? Correct me if I'm wrong but should I not see "ip routing" under ip subnet-zero?
4507(config)#ip routing
4507(config)#do sh run
Building configuration...
Current configuration : 6549 bytes
version 15.0
no service pad
service password-encryption
service compress-config
hostname DUR-4507
boot-start-marker
boot-end-marker
enable secret 5 $1$i6GY$ik/W1flFchFCYejHaFgOz/
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp domain null
vtp mode transparent
Jon Marshall
Harold
It differs per switch model as to what is the default.
So if you typed "no ip routing" that should show in your configuration.
But if "ip routing" is on by default it won't necessarily be there.
Jon
Jon Marshall
Harold
Jon
Thanks Jon, tested and you're correct.
Harold
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might also try a "show run all".
