Enabling SSH on CatOS
londint
Level 7
Level 7
Hi All
Now that I have upgraded a Cat4006 Switch to the SSH version 8.4.11.GLX-K9. I have also generated the SSH keys and put in a permit ip list.
How do I set the Switch up with a username and psssword so that I can use my Client SSH SecureShell to connect to the Switch?
ankbhasi
Hi Friend,
set localuser user username password pwd privilege privilege_level
Have a look at this link for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_3/configur/authent.htm#wp1122817
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_3/configur/authent.htm#wp1128465
Ankur
*Pls rate all helpfull post
Thanks for your help
londint
Level 7
Level 7
Thanks.
I eventually found out on the switch.
